Results 1 to 4 of 4
Thread: Rescue training for patient trapped under tree - GIF
  2. The Following 5 Users Say Thank You to ToolTalkBot For This Useful Post:
    clydeman (Aug 22, 2024), KustomsbyKent (Aug 22, 2024), nova_robotics (Aug 26, 2024), that_other_guy (Aug 25, 2024), Tule (Aug 23, 2024)
    Sep 2018
    nova_robotics's Tools
    Doesn't look like a very efficient way of lifting a tree off a person.
    I'm guessing it would depend on the circumstances, and location. A 3-point lift system reduces the chance to the tree shifting while being raised, if placement is at optimal angles. The spin lock safeties on the hyd. cylinders assure, they will not accidently bleed off in event of a broken hose. Trees are notorious about not acting as you think they should limb age makes them more dangerous roots that may be keeping a tree from rolling can break at the worst time. Even if you had a yarder to pick the tree off of a victim you can find yourself or the victim in an even more dangerous situation if you try to use the yarder with its claw to lift a tree.
    From the Paratech logo on the webbing: https://paratech.com/markets/fire-rescue/
  6. The Following User Says Thank You to Jon For This Useful Post:
    Frank S (Aug 26, 2024)
