Results 1 to 4 of 4
Thread: Repairing 1/2" PVC Irrigation Pipe
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    Schedule 40 1/2 inch PVC pipe is great for irrigation. This pipe is not going to burst due to age like soft pipe but can be damage if hit by a shovel or pick axe. Repairs can require digging a large trench so the ends of the pipe can be bent enough to accept a standard coupler. Alternately, you can buy a telescoping repair coupler for about $5 and dig a shorter trench. But what about making a coupler on your lathe that does the same thing? The cost is near zero and the machine time is small.
    You can also cut one of these couplers in half and get two patches. These patches can be cemented onto the pipe over a small damaged area.
    Both the coupler and patch were tested at full city water pressure. No leaks were observed.
    http://rick.sparber.org/SCAP.pdf
    Thanks,
    Rick
    Rick
  2. #2
    Supporting Member Ed ke6bnl's Avatar
    Mar 2012
    So. California high desert
    Ed ke6bnl's Tools
    Great job, I will try either or both when the job comes up, it is so easy to turn and do on the lathe that it is not necessary to make them in advance and not find them, but to do it when needed. thanks for the testing
    1950 F1 street rod
    1949 F1 stock V8 flathead
    1948 F6 350 chevy/rest stock, no dump bed
    1953 chevy 3100 AD for 85 S10 frame going for a 4BT cummins motor, NV4500
    1968 Baha Bug with 2.2 ecotec motor, king coil-overs,P/S
    2000 National Sea Breeze 5th wheel trailer
    1998.5 Dodge 2500 4x4 Cummins,
  3. #3
    Thanks Rick! We've added your PVC Stop Cutter to our Miscellaneous category, as well as to your builder page: Rick's Homemade Tools. Your receipt:
  4. #4
    Thanks Rick! We've added your PVC Pipe Coupler to our Farm and Garden category, as well as to your builder page: Rick's Homemade Tools. Your receipt:
