Results 1 to 7 of 7
Thread: Removing Powder Coat Paint
    batchit's Avatar
    Apr 2021
    Hi all, I like to recycle as much as possible and often come across steel and metal that is powder coated. My method at the moment is to use a gas torch to scorch it and use a wire wheel to remove the burnt offerings. This method causes nasty fumes and smoke which is not good, so I was wondering if anyone could think of a better way that this could be done.
    Regards
    Geoff
  2. The Following User Says Thank You to batchit For This Useful Post:
    Philip Davies (Mar 16, 2022)
    Aug 2019
    Oregon, USA
    BuffaloJohn's Tools
    I'd use a stripper product as my first choice.
    There are a bunch of companies out there that sell pretty reasonable products - might look to automotive products.
    When welding, I have had to remove powder coating and if its a get the job done now, I'll use the torch. If I have to pull out the angle grinder to clean up the to be welded edges, grinding powder coating gums up, wire wheels aren't much better.
  4. The Following User Says Thank You to BuffaloJohn For This Useful Post:
    Jul 2014
    North Island, New Zealand.
    NortonDommi's Tools
    Wet abrasive blasting will strip it off very quick and leave a smoother surface than dry blasting.
    https://www.dustlessblasting.com/blo...ical-stripping
    This bloke has a good channel showing some nice modifications for the universal benchtop blasting cabinet that is perfect for most of the stuff you will recycle even if you need to break stuff down to fit,(you'll probably be doing that anyway):
    https://www.youtube.com/c/ArmouryEnterprises
  6. The Following 2 Users Say Thank You to NortonDommi For This Useful Post:
    BuffaloJohn (Mar 16, 2022), Philip Davies (Mar 16, 2022)
    Sep 2018
    nova_robotics's Tools
    The spongy looking abrasive discs for angle grinders are by far the best way to remove paint in a hurry. They go by a few different names, one of which is "Poly Strip". Sandblasting can't touch it for speed. I've never tried it on powder coat but I'm assuming it would be similar.
  8. The Following User Says Thank You to nova_robotics For This Useful Post:
    batchit's Avatar
    Apr 2021
    I have been watching Josh's videos for a while now and has some good stuff on there, just need the bucks and time. I got one of those sand blaster gun setup to put on a pressure sprayer but I have not tried it yet.
  10. #6
    Aug 2019
    Oregon, USA
    BuffaloJohn's Tools
    The spongy looking abrasive discs for angle grinders are by far the best way to remove paint in a hurry. ...SNIP... I've never tried it on powder coat but I'm assuming it would be similar.
    I have zero success with those type of disks on powder coating, it just clogs up and then metls itself into the disk.
    Paint - okay, powder coat - no way... my two cents...
  11. #7
    May 2015
    Tasmania, Australia
    Bony's Tools
    I use paint stripper, lay it on thickly, wait and it washes off. Quite co$tly if you have a large surface area though.
    The abrasive wheels remove the paint but it melts onto the wheel.
