Results 1 to 1 of 1
Thread: Reduce Branch Quantity - Machine Build (fail?)
    Supporting Member darus627's Avatar
    Jan 2017
    Poland
    darus627's Tools
    You know that we really like machines for wood, branches, etc. That's why we decided to make another such machine.
    This time we used a combustion engine with a power of 7 HP (actually it is probably 4 HP), a 1:100 planetary gear and a cutting mechanism of our own making.
    Unfortunately, as you saw, the gear seized up and stopped. I'm not sure what the reason was, but I suspect two possibilities.
    The gears were already a bit worn and I didn't know about it because I didn't look inside before starting the project or 3600 engine rpm was too much for this gear. From what I remember, it worked with a 1400 rpm engine and maybe that's the problem.
    Life goes on and you have to move on to another project. Maybe we'll come back to this
  2. The Following User Says Thank You to darus627 For This Useful Post:
    nova_robotics (Jul 1, 2024)
