Results 1 to 10 of 11
Thread: Raising a truck's dump bed under power lines - GIF
  2. The Following 9 Users Say Thank You to Jon For This Useful Post:
    baja (Jan 10, 2019), durrelltn (Jul 16, 2022), EnginePaul (Dec 4, 2020), KustomsbyKent (Jan 10, 2019), Miloslav (Nov 25, 2019), oldpastit (Jan 13, 2019), Rangi (Jan 17, 2022), Seedtick (Jan 10, 2019), will52100 (Jan 10, 2019)
    Its clear this wasn't the first load of macadam that had been dumped there and there was a guy on the ground who looked like he was checking the distance between the bed and the power lines.
    The bed did not touch the lines or they would have burnt into instantly so it was purely a matter of voltage jump. maybe the bed got closer then previously or the humidity had gone up or the wind caused the lines to move up and down, or more probably they had just been lucky so far.
    Jan 2018
    Black Mountain Queensland
    ranald's Tools
    It would seem that the belly in the lines were not properly considered as well as the small rise in the truck as the load was reduced. Maybe they should have dumped all loads before spreading which in itself reduced clearance. The jurking didn't help either.
    When working at local authority a driver hit lines which is a fairly common thing apparently. He was electricuted but survived. Govt ads promote "look up & live".
    These guys were courting danger.
    Supporting Member aphilipmarcou's Avatar
    Dec 2016
    new zealand
    aphilipmarcou's Tools
    One way of making toast....
    Jan 2018
    ranald's Tools
    Quote Originally Posted by aphilipmarcou View Post
    Ha Ha, Burnt toast never smelt so bad.
    Jul 2016
    The belly in the lines can change with load hence temperature of the lines. More load, more heat, more sag. Wonder if this came into play.
    Eric
  9. The Following User Says Thank You to suther51 For This Useful Post:
    PJs (Jan 11, 2019)
  10. #7
    Jan 2018
    ranald's Tools
    Quote Originally Posted by suther51 View Post
    Eric
    Yep Eric. For the many reasons, we have an exclusion zone of 3 metres & with high voltage it increases to 6m or 8m. those guys were tempting fate.
  11. #8
    Supporting Member toma's Avatar
    Serbia
    toma's Tools
    Do not play with high voltage..
  12. #9
    PJs
    PJs is offline
    Sep 2014
    Northern CA
    PJs's Tools
    Wait for it....Wait for it.....Sqrzzzzzttzzz. Looked like perhaps one was touching and got close enough to the second one to arc across. Surprised he didn't loose control and go roaring down the hill. Don't worry honey, it'll grow back.
    Mark Twain
  13. #10
    Supporting Member stillldoinit's Avatar
    May 2013
    stillldoinit's Tools
    Wonder if the company keeps a stock of clean shorts for emergencies.
