Page 3 of 3 FirstFirst 1 2 3
Results 21 to 24 of 24
Thread: Radius gauge and reverse engineering
  1. #21
    Quote Originally Posted by prm View Post
    Tony,
    I hope you won't mind if I also note that there are some typos in the pdf file : in the sections were you discuss errors in the indicator reading and errors in measuring the probe spacing, the radius value are not correct.
    Regards,
    Paul
    I found the typo in the indicator reading section. I wrote 49.97 which should have been 4.97.
    I can't find the error in the probe spacing part.
  2. #22
    Dec 2016
    There is a similar gauge used in optics. I think it is called a diopter gauge and it is used to measure the curvature of a lens or a mirror. Nice tool, Tony!
    Jan 2016
    Southern tip of Vancouver Island
    Thumbs up Slopes of perpendicular lines
    I have just enhanced the software to allow calculation of the curve radius and centre coordinates when the XY coordinates of three points on a curve are known.
    This is useful if you use the DRO on a milling machine to determine the coordinates of three points. This does not need the radius gauge described above.
    The link to the software is the same as that in the PDF RadiusGauge.pdf
    Tony, a typo in the pdf´s Appendix:
    ¨Firstly we calculate the slope of the two lines AB and BC, then we bisect lines AB and BC with normal lines (shown in red), these will meet at the centre. The slopes of these two lines are obtained by multiplying the slopes of AB and BC by -1¨.
    This holds true only for slopes of 1 or -1. Perpendicular lines have slopes that are negative reciprocals of each other.
    In the diagram, by inspection, line segment AB has slope of about one half. AB´s red perpendicular bisector has slope about -2.
  4. #24
    Quote Originally Posted by volodar View Post
    Of course, you are correct. That was a stupid mistake.
    PS. File has been fixed.
    Last edited by tonyfoale; Mar 19, 2019 at 09:45 AM. Reason: Correcting brain fart.
  5. The Following User Says Thank You to tonyfoale For This Useful Post:
    volodar (Mar 19, 2019)
