Thread: QCTP height setup
    Jul 2014
    France, Brittany !
    Christophe Mineau's Tools
    QCTP height setup
    Hi,
    I frequently use my QCTP for holding my Dremel, for grinding or sanding on the lathe.
    Then, I need to be able to setup the height along the vertical axis with a wider range than what simply permits the QCTP.
    I have imagined this simple setup that allows for setting up the tool both lower and higher than what is possible with the original system.
    I replaced the set screw by a long screw, and I inserted this angled piece of metal sheet under the handle.
    The knurled knob stops against this inserted stop, and the vertical setting up range is widely enhanced.
    Of course, when I come to be limited, I shift to my milling square, but this takes more time to install.
    Cheers !
    Christophe
    Facebook : La Belle Note
  2. The Following 7 Users Say Thank You to Christophe Mineau For This Useful Post:
    desbromilow (Jan 6, 2023), HUMARIA (Jul 22, 2019), Jon (Nov 17, 2015), kbalch (Nov 17, 2015), Paul Jones (Nov 17, 2015), PJs (Nov 17, 2015), Toolmaker51 (Sep 11, 2016)
    Thanks Christophe! We've added your QCTP Height Setup Method to our Rotary Tools category, as well as to your builder page: Christophe's Homemade Tools. Your receipt:
