Results 1 to 7 of 7
Thread: QCTP Bracket for Test Indicator Holder Arm
    May 2014
    Del Mar, California
    Paul Jones's Tools
    I have been using magnetic test indicator holders with the quick release magnetic bases for setup work on the lathes. However, I thought it might be easier to use a flexible arm held in the quick change tool post for most of this work. Shown is an easy to make aluminum bracket designed to fit in the same space as a 3/8” square cutting tool holder. The bracket part was made from 0.625"x1.25” 6061 aluminum bar stock, milled and fly cut to size, drilled and reamed with 5/16” diameter holes to hold the adjustable arm base in either horizontal or vertical positions, and locked in place with an 8-32 SS cap screw. I purchased Shars Tool online the adjustable test indicator holder arm that fits any test indicators with either 3/8” diameter shafts and/or side dovetails.
  2. The Following 2 Users Say Thank You to Paul Jones For This Useful Post:
    Catfish (Dec 19, 2014), kbalch (Dec 18, 2014)
    kbalch's Avatar
    Jun 2012
    Clermont, FL
    Thanks Paul! I've added your QCTP Bracket to our Machining categor, as well as to your builder page: Paul Jones' Homemade Tools. Your receipt:
  4. The Following User Says Thank You to kbalch For This Useful Post:
    Jul 2014
    France, Brittany !
    Christophe Mineau's Tools
    Hi Paul,
    Nice tool, neatly done.
    Could you develop more why you find it easier than the quick release magnetic base ?
    Thanks,
    Christophe
    Cheers !
    Christophe
    Facebook : La Belle Note
    May 2014
    Del Mar, California
    Paul Jones's Tools
    Christophe,
    Great question and probably my unique problem. The two issues I have with my magnetic bases are: my failure to totally release the magnetic lever and end up scratching the paint on the machine tools or the machined surfaces (my operator error but nonetheless something I dislike doing); and 2) my magnetic test indicator holders have the conventional stiff vertical rod with a hard-to-adjust horizontal rod and usually requires several additional adjustments and/or moving the carriage to locate the dial indicator. Perhaps installing the flexible arm (the blue and black parts in the photos) onto the magnetic bases would be a tremendous improvement. Also, on my other small Unimat lathe (shown in other posts to HMT), I plan to permanently install similar aluminum holders into the cabinet base for attaching the flexible arm as needed (on the Unimat there a few steel/cast iron surfaces for magnetic attachment). I hope this helps with understanding my reasons.
    Paul
    Jul 2014
    San DIEGO, California
    Captainleeward's Tools
    W0W, NICE addition to your tool bin.!!!!
  8. The Following User Says Thank You to Captainleeward For This Useful Post:
    Paul Jones (Dec 18, 2014)
    Supporting Member Catfish's Avatar
    Oct 2013
    Mariposa, California
    Catfish's Tools
    Very nice Paul. I like it, now I have to build one. I have the same kind of problems on my Logan lathe. Thanks for sharing your idea. Randy
  10. #7
    Jul 2014
    France, Brittany !
    Paul
    Ok understood.
    Cheers !
    Christophe
