Results 1 to 4 of 4
Thread: Power Caster
    Apr 2014
    Gadgeteer's Tools
    Power Caster
    Here's a project I completed a few decades ago. I got tired from moving a rather large utility trailer around by hand, so put together his handy device. Power is supplied by a small HF 12 VDC winch, converted to chain drive by adding a sprocket to the cable spool. In/out reversing switch that came with the winch provides for reversing directions. Triangular design with split frame facilitates easy chain tensioning by sliding motor. Wheel is stolen off of a wheel borrow. Black pipe for handle. Easily moved the trailer with a full load of firewood.
    Attached Thumbnails Attached Thumbnails Power Caster-power-casterb.jpg   Power Caster-power-caster1.jpg
  2. The Following 9 Users Say Thank You to Gadgeteer For This Useful Post:
    Andyt (Jan 12, 2021), baja (Jan 12, 2021), Big-Pete (Jan 11, 2021), dubbby (Jan 11, 2021), Jon (Jan 11, 2021), Priemsy (Jan 17, 2021), rlm98253 (Jan 11, 2021), Saltfever (Jan 13, 2021), Toolmaker51 (Jan 17, 2021)
    Thanks Gadgeteer! We've added your Power Caster to our Trailers and Towing category,
    as well as to your builder page: Gadgeteer's Homemade Tools. Your receipt:
    Sep 2018
    I'm glade i found this power caster.
    I will build this ASAP have a shop that is over packed and I need this type of tool to move equipment.
    Thank you for you ingenuity.
    dell
    Apr 2014
    Gadgeteer's Tools
    I should have mentioned that I added a bolt-on pipe receptacle to the tongue of anything I moved with the power caster. If the one-wheel caster is used with a ball, it will fall to a side.
  6. The Following User Says Thank You to Gadgeteer For This Useful Post:
