Results 1 to 4 of 4
Thread: Portable Air Tank
    May 2012
    Byron, Michigan
    astroracer's Tools
    Portable Air Tank
    I picked up this cheap pancake air compressor at Sears 5 or 6 years ago. The little compressor finally took a dump so I turned the tank into a portable one and saved the motor. The motor still works, just doesn't compress air anymore.
    I made this adapter from two quick disconnect fittings so I can fill the tank right from my air hose.
    I just plug the fittings together and crack the ball valve on the hose until the little tank has about 90 PSI in it.
    Turn off the valve and unplug the fitting from the tank. It fills pretty quick. It's only 3 gallons...
    Mark
  2. The Following 2 Users Say Thank You to astroracer For This Useful Post:
    Jon (Aug 30, 2016), Paul Jones (Sep 1, 2016)
    Thanks astroracer! We've added your Portable Air Tank to our Air Compressors category,
    as well as to your builder page: astroracer's Homemade Tools. Your receipt:
    Sep 2016
    Damn! NICE Connection Idea, THX !
    May 2012
    Byron, Michigan
    astroracer's Tools
    Thanks! I've already used this thing a couple of times. I am going to re-do the QD fitting. I am going to put a 90 degree elbow in place of the adapter fitting so I can put the original handle back on. Right no it will block access to the fitting when screwed back on.
