Thread: Pop Rivet Drill Guide
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    Have you ever tried to drill out a Pop Rivet and had the top get stuck on the drill or, even worse, have the entire rivet spin – preventing further drilling? This tool solves these problems.
    If you are interested, please click here
    Thanks,
    Rick
    Rick
  2. The Following 4 Users Say Thank You to rgsparber For This Useful Post:
    ductape (Jan 28, 2024), Jon (Feb 1, 2024), PJs (Jan 30, 2024), rebuilder1954 (Feb 5, 2024)
    Thanks rgsparber! We've added your Pop Rivet Drill Guide to our Fastening category,
    Supporting Member tachetailleur's Avatar
    May 2022
    Thank you for the ideas, I find that to be a very interesting and thought provoking project. When I drill rivets out I use a battery drill with a reverse function, allow a certain number of rings to build up on the bit, then hold them in pliers and reverse the drill to take them off. It's still tedious, though. I tend to use aluminium sheet and one disadvantage for me might be the overhanging bandsaw teeth marring the surface away from the rivet. Perhaps they could be ground down or covered over. In fairness, I rarely get away with an unscathed surface anyway! On a side note, I find that dipping the drill tip in alcohol between cuts stops the aluminium smearing onto it, but if I've used a permanent marker nearby it often gets removed by the excess alcohol coming off the bit...
