Thread: Poor man boring bar
    Nov 2015
    Italy
    rendoman's Tools
    Poor man boring bar
    Hi!
    Not a great tool, in fact I modified an old boring bar in order to cut large holes in light materials.
    I created a sort of guide in the lower part of the tool (10mm) , so that it can be inserted into a pre-hole drilled in the part. The cutting tool is an old broken tap grinded.
    I cut a 45mm hole in 3mm aluminum with drill press, I haven't noticed any particular problems or vibrations, the guide worked well.
    I don't recommend to use with drill press, the milling machine is the safest way. In particular, vibrations could easily detach the morse cone from its seat.
    Poor man boring bar-img_20200428_173630_900x1200.jpg Poor man boring bar-img_20200428_173638_900x1200.jpg
  2. The Following 2 Users Say Thank You to rendoman For This Useful Post:
    EnginePaul (Apr 29, 2020), Jon (Apr 30, 2020)
    Thanks rendoman! We've added your Boring Bar to our Machining category,
    as well as to your builder page: rendoman's Homemade Tools. Your receipt:
