Page 2 of 2 FirstFirst 1 2
Results 11 to 12 of 12
Thread: Pneumatic Power Drawbar for Bridgeport Mill
    Supporting Member tmate3's Avatar
    Jan 2021
    tmate3's Tools
    When you drilled and tapped the aluminum casting, how did you keep the resulting chips and debris from falling into the head?
  2. #12
    Berkshire UK
    thehomeengineer's Tools
    Quote Originally Posted by tmate3 View Post
    Hi
    I also fitted a digital tachometer and this was set up on the back gear in the head. This then ensures the speed is correct in both high and low ranges. So the head was stripped down for this and the aluminium casting drilled off the machine. It also was a good time to change the two belts as it was all apart.
    hope this answers your question
    The Home Engineer
