Pneumatic nibbler cutting 3/16" steel.
HOMEMADE NIBBLER || Let's Learn Something
Homemade metal nibbler stand - video
Giant slip roller - GIF
Hot strip mill slab feed table - GIF
Andyt (Jan 12, 2020), baja (Jan 8, 2020), clydeman (Jan 11, 2020), greyhoundollie (Jan 7, 2020), KustomsbyKent (Jan 7, 2020), mwmkravchenko (Jan 7, 2020), olderdan (Jan 7, 2020), Seedtick (Jan 7, 2020), thehomeengineer (Jan 7, 2020), Tonyg (Jan 10, 2020), Toolmaker51 (Jan 12, 2020)
Yup! Unitec:
https://www.csunitec.com/saws/electr...ers-and-shears
For cutting sheet metal, steel plate, weldments and double sheets
Cuts steel up to 3/8" thick and aluminum up to 1/2" thick
Head can be rotated to four 90° positions
Cut over 90° bends with optional die
Charles Waugh
www.charleswaugh.com
clydeman (Jan 11, 2020), greyhoundollie (Jan 7, 2020), Jon (Jan 7, 2020), mwmkravchenko (Jan 7, 2020)
bigtrev8xl (Jan 8, 2020)
https://www.mmtoolparts.com/store/cs...t-min-cs-500-e
Lists a model that'll do 3/16" plate at roughly $3300
Charles Waugh
I frequently use a Makita nibbler but it is pushing the limits to cut 1.5 mm mild steel sheet.
The noise from one that cuts 3/8" plate must be horrendous.
