Results 1 to 10 of 12
Thread: Pneumatic air graver from stainless steel bolt - video
    Pneumatic air graver from stainless steel bolt. By AMbros Custom. 11:55 video:
    Hobo nickels: intricate carvings in coins - GIF and photos
    Push graver - video
  2. The Following 11 Users Say Thank You to Jon For This Useful Post:
    baja (Dec 4, 2020), blkadder (Dec 6, 2020), CharlesWaugh (Dec 3, 2020), davidschutt (Dec 4, 2020), Eaglewood (Dec 3, 2020), Frank S (Dec 3, 2020), GKK (Dec 3, 2020), Home-PC (Dec 7, 2020), madmick77 (Dec 3, 2020), mwmkravchenko (Dec 3, 2020), NortonDommi (Dec 3, 2020)
    May 2018
    Boring, OR
    CharlesWaugh's Tools
    Excellent video! Thank you!
    Charles Waugh
    www.charleswaugh.com
    Jul 2014
    North Island, New Zealand.
    NortonDommi's Tools
    Great video that shows that where there is a will there is usually a way. Brought back memories of working before I had as many tools as today and made me realise just how lucky I am.
    Jun 2018
    Louisiana
    With some very basic tools where is a will there is a way
    seeing the finished tool you would never suspect it was made mostly with a file a hand drill and a small angle grinder
    mlochala's Avatar
    Nov 2012
    mlochala's Tools
    Man, what an excellent video. Loved the music. Very impressed with your workmanship skills, especially using a drill and angle grinder in place of a lathe.
    Awesome stuff!
  8. #7
    Aug 2016
    wizard69's Tools
    Excellent video. I was watching on a cell phone and AT&T would cause the video to freeze every couple of minutes - I wanted to scream. This only seems to happen on the really good videos.
    In any event a little advice on drilling stainless:
    1. Keep the spindle speed low, at least half of what you might use in steel.
    2. Never allow the drill to rub.
    3. Use a good cutting oil. WD 40 doesn’t cut it in stainless.
    Having had my share of problems working stainless steel the above are hard earned guidelines.
    In any event this video has stirred an interest in engraving. Well done!
  9. #8
    Supporting Member McDesign's Avatar
    Sep 2016
    McDesign's Tools
    Quote Originally Posted by wizard69 View Post
    Me, too! Must think about this . . .
  10. #9
    Supporting Member blkadder's Avatar
    May 2012
    Florida, USA
    I have always wanted to give graving a try. This is a pretty good example of making a pneumatic graver. I never knew all you needed was a small air pump. I was under the impression that it required a huge compressor. Maybe I'll add this to my seemingly endless list of projects.
    Ron
    ...Semper Fidelis...
  11. #10
    Shaun Hughes's YouTube channel is a good place to go if you want to get into engraving. He also built his own machine, and he does a lot of hobo nickels.
  12. The Following User Says Thank You to Jon For This Useful Post:
