Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
Thread: please help ID mystery tool?
    Lake Tahoe
    IntheGroove's Tools
    "flat/ chisel edge at each end"
    "The point end was placed inside a large split pins"
    Are both ends flat or is one end pointy?
  2. #12
    Nov 2019
    Bateau Bay NSW Australia
    Hi every one, in Australia we use these for steel erection. The taper end is for lining up bolt holes and the taper end for lifting and leveling. We call these tools a "Podger bar".
    Quote Originally Posted by desbromilow View Post
    Folks,
    hopefully someone might know what this tool is... forged steel, flat/ chisel edge at each end, rest of the body is round in cross section except the end at the top of the image, no markings. Ruler in the image is metric millimeters.
    Attachment 45572
    Aug 2012
    Australia
    desbromilow's Tools
    Quote Originally Posted by IntheGroove View Post
    this one has both ends chisel shaped
  4. The Following User Says Thank You to desbromilow For This Useful Post:
    IntheGroove (Jun 13, 2023)
  5. #14
    greenie's Avatar
    Dec 2018
    greenie's Tools
    Quote Originally Posted by john 1938 View Post
    Nope, sorry John 1938 --- NOT a Podger bar, a Podger bar has a pointy end to stick into holes, to force the two holes into alignment and normally has something like a hammer head at the other end, or sometimes a spanner. This bar in question, ----- has flats at both ends.
  6. #15
    ronaldb's Avatar
    Oct 2019
    In 1974 I bought a large split pin selection kit., 800 pieces, 1.2mm to 6,4mm, that had 2 of those split pin Tommie bars included, 1 small and one large. I still have both, and a myriad splitpins.
