Results 1 to 5 of 5
Thread: Plastic pellet extruder - GIF
  2. The Following 4 Users Say Thank You to Altair For This Useful Post:
    mwmkravchenko (Mar 25, 2021), nova_robotics (Mar 24, 2021), Rangi (Mar 30, 2022), Wildwilly (Mar 24, 2021)
    Jul 2019
    Could someone enlighten me as to why the drive chains are run so loose?
    Dec 2014
    South Dakota
    KustomsbyKent's Tools
    Likely so that they can take the chain off easily to change the extruder die easier.
  5. The Following User Says Thank You to KustomsbyKent For This Useful Post:
    Jul 2019
    Quote Originally Posted by KustomsbyKent View Post
    Sorry but I fail to believe that. By the looks of things there is double the slack that would be needed for that. But, if what you say is true, then it is a very poor design. A better design would be a spring loaded idler.
    Unkle Fuzzy's Avatar
    Near Monkeytown, USA
    Changing the sprocket size will shorten or lengthen the pellet so I would say extra slack is for a larger sprocket that would result in a longer pellet.
    The cutter that the sprocket drives is really under very little load so the slack is of very little concern.
  8. The Following User Says Thank You to Unkle Fuzzy For This Useful Post:
