Results 1 to 7 of 7
Thread: Perfect & Easy Make Dado & Rabbet Joint - KERFMAKER
    Supporting Member Didpoolhall's Avatar
    Feb 2019
    indonesia
    Didpoolhall's Tools
    Simple easy-to-make table saw jig that will let you cut perfect dados and rabbet with only the use of a single table saw blade. I had some leftover pieces from my last project. So I decided to make something out of it. This woodworking jig is made from scrap plywood and a few bits of hardware found in almost every workshop. Once set the Kerfmaker right, it works perfectly every time. Easy and repeated make dado slot & rabbet Joint
  2. The Following 4 Users Say Thank You to Didpoolhall For This Useful Post:
    dheiser4 (Dec 31, 2020), Jon (Dec 30, 2020), lasten (Jan 2, 2021), sacco1 (Dec 30, 2020)
    Thanks Didpoolhall! We've added your Kerfmaker to our Jigs category,
    as well as to your builder page: Didpoolhall's Homemade Tools. Your receipt:
    Dec 2016
    Ralphxyz's Tools
    Nice, thanks for posting. What was the purpose of the screw in the end, not sure what you were setting.
    Ralph
    Cleveland Ohio
    Redwoods's Tools
    The screw is for fine adjustment.
    Dec 2016
    Ralphxyz's Tools
    Thanks but fine adjustment of what? Why?
    Ralph
    Cleveland Ohio
    Redwoods's Tools
    The tightness or looseness. Moving the screw in or out changes the width of the cut.
  8. #7
    Dec 2016
    Ralphxyz's Tools
    I just need to watch the video a few more times.
    Ralph
