johncg (Jan 6, 2022), mwmkravchenko (Jan 2, 2022), nova_robotics (Jan 5, 2022), Ralphxyz (Jan 5, 2022)
Frank S (Jan 2, 2022)
mwmkravchenko (Jan 3, 2022)
it is MINIMAL extra cost to do the job PROPERLY. What happens if the "repairer" and I use the term loosely! doesn't have a suitable sized hole saw, or if the hole is substantially irregular (larger). It then has to be done the way Inflight stated, the correct way (and I agree).
Apart from doing the job correctly, the nett result of a correctly applied repair, is a less visible repair. This method leaves a "huge" patch on the wall, when a proper repair leaves almost no patch and certainly no large "lump" on the wall.
