Results 1 to 4 of 4
Thread: Painting a speaker - GIF
    that_other_guy (Oct 17, 2022)
    Lake Tahoe
    IntheGroove's Tools
    I have quite a few speakers and none of them are painted. That would definitely change the tone...
    Dec 2017
    NeiljohnUK's Tools
    Looks like rubber paint to seal the cone against water ingress/beer splashes (I worked in the night club sound and lighting game years ago), we did the same to Bose 101's facing the sea on a bar wall, extended the life from ~18 months to ~5 years. Most speakers only change response slightly due to the extra weight to move, though many speakers are now made with plastic cones for such use, I see polished Aluminium cones are now popular for high power systems where paper, even rubber painted, cannot cope with the high power large movements required.
    Supporting Member schuylergrace's Avatar
    Sep 2020
    Mesa, Arizona
    I'm not completely certain what that coating is, but speaker manufacturers often use a black coating like that to stiffen a paper cone, which makes it more responsive and less affected by changes in humidity. Many older radios used coated speakers to allow one large speaker to produce both high and low frequencies. Today, you'll find coated speakers in high performance and/or high amplitude systems.
    For topical application, only. Not to be taken internally or used in com-
    bination with other drugs or alcohol, except as directed by your shaman.
    Do not operate heavy equipment, unless you actually know how to.
