This is a simple modification of a brass tumbler that will make it able to effectively shake paint. The key is changing (slowing) the motor speed.
Thanks TigerCreek! We've added your Paint Shaker to our Painting category,
as well as to your builder page: TigerCreek's Homemade Tools. Your receipt:
If it doesn't seem aggressive enough for your particular application, two simple things that can be done to increase the "shaking".
One, replace the stock springs with longer or weaker springs.
Two, increase the amount of offset weight on the shaft.
I used this fabrication because it worked well for my particular needs, and it is a very easy modification.
