Page 2 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 11 to 20 of 44
Thread: Packaging roller bearings - GIF
    applying just enough grease to hold the balls in the cup. Caster bearings are a about the cheapest form of ball bearings there are.
  2. #12
    Marion, Iowa
    metric_taper's Tools
    This reminds me of garage door extension spring pulleys where the outer race is stamped sheet metal. The two halves are riveted either with pierced sheet metal that is staked, or real rivets. These have a life where they eventually pull apart from the cable tension. I made solid steel pulleys and used dual ball bearings as replacements were not as robust as the original pulleys. Last month, I just replaced the 4 extension springs as one failed and the others were about to. Always fun to fix one issue and then the next weak link fails.
  3. The Following User Says Thank You to metric_taper For This Useful Post:
    Scotsman Hosie (Apr 10, 2019)
  4. #13
    Just figured out why roller conveyor wheels are so economical...and plentiful
    At .03 and .05, manipulations of the cup, is the nozzle misting lube? Very efficient, versus oiling the balls would cause adhering to others. The intent is clear, but can't quite work out why cup on deck faces down. She clearly has them pre-staged in right hand, race side up. The post in bowl of bearings is surely pneumatic, but a pedal and lever would work too.
    I'm certain very nearby someone's pressing the other side on, making up tote bins of wheels. All the shipping fullfillment centers worldwide are using these by the thousands, not to mention what's used in general manufacturing.
  5. #14
    Sep 2018
    Explains why cheap bearings always seem to be sloppy with missing balls. I assume the grease doesn't always hold all the bearings.
  6. #15
    PJs
    PJs is offline
    Sep 2014
    Northern CA
    PJs's Tools
    Lazy Susan bearings ?
    Mark Twain
  7. #16
    Supporting Member Al8236's Avatar
    Dec 2014
    Kendall Washington
    Al8236's Tools
    Quality control! Looks like the first one is missing a ball!
    From the time you're born till' you ride in a hearse, there's nothing so bad it couldn't be worse!
  8. The Following User Says Thank You to Al8236 For This Useful Post:
  9. #17
  10. #18
  11. The Following 5 Users Say Thank You to Jon For This Useful Post:
    baja (Jan 10, 2019), hansgoudzwaard (Apr 26, 2019), PJs (Jan 11, 2019), Scotsman Hosie (Apr 10, 2019), Seedtick (Jan 10, 2019)
  12. #19
    Apr 2014
    Gadgeteer's Tools
    <source src="https://diqn32j8nouaz.cloudfront.net/hand_packing_printer_paper.mp4" type="video/mp4">
    </video>
    And, notice the guy loading the paper cutting machine behind the packager.
  13. The Following 2 Users Say Thank You to Gadgeteer For This Useful Post:
  14. #20
    Jan 2018
    Black Mountain Queensland
    ranald's Tools
    I'd employ her at that rate. bet she gets US$1 a day poor thing. These days robots do that elsewhere.
