Results 1 to 7 of 7
Thread: Oxy-fuel cutting a sprocket - GIF
    Oxy-fuel cutting a sprocket.
    Cutting sprocket teeth - GIF
    Waterjet cutting an aluminum sprocket - GIF
    Induction heating sprocket teeth - GIF
    mwmkravchenko (Dec 18, 2021), nova_robotics (Dec 18, 2021)
    Perth Ontario Canada
    Don't need no stinking plasma, or LASER's with Frikkin sharks
  4. The Following User Says Thank You to mwmkravchenko For This Useful Post:
    Quote Originally Posted by mwmkravchenko View Post
    Plasma is about the worst thing to use when cutting thick metal and needing a perfectly perpendicular cut
    Oct 2019
    Yep. Since the plasma stream is spinning it tends to run to one side. This leaves a pronounced bevel on one side of the cut.
  8. The Following 2 Users Say Thank You to graniteguy For This Useful Post:
    BuffaloJohn (Dec 19, 2021), mwmkravchenko (Dec 18, 2021)
    Sep 2018
    nova_robotics's Tools
    Yup. Even waterjet cuts a wedge. Some of the higher end machines can tilt the head so that the finished side of the cut is perpendicular to the material (at the expense of the other side).
    I made a CNC flame cutter years ago. It was just a 2 axis machine though. It didn't have any of the fancy stuff like the ability to tilt the torch.
  10. The Following User Says Thank You to nova_robotics For This Useful Post:
  11. #6
    Actually I should have said a near perfectly perpendicular cur as even the kerf of an oxy fuel flame will show some variation in very thick metals such as in making cuts through metals over 6 or 8 inches thick. But with a properly cleaned tip and the correct mixture and pressure settings the variation is negligible
    mwmkravchenko (Dec 19, 2021)
  13. #7
    Dec 2016
    Ralphxyz's Tools
    Unbelievable what a "clean" tip does, I worked with a welder who was a fanatic about having a clean tip. When he cut 1/2" plate you could cut yourself on the edge if you were not careful.
    Ralph
  14. The Following User Says Thank You to Ralphxyz For This Useful Post:
    mwmkravchenko (Dec 25, 2021)
