Results 1 to 6 of 6
Thread: Over-the-tire tracks - GIF
    Inner (Oct 6, 2022), johncg (Oct 7, 2022)
    Elizabeth Greene's Tools
    Do they stretch the tread to get it on or do the axles move closer? I don't see an idle roller.
    I have questions.
    Quote Originally Posted by Elizabeth Greene View Post
    I have questions.
    Just remove 1 outside tire stretch the track over the remaining tires then re install the tire
    katy (Oct 9, 2022)
    katy's Avatar
    Jul 2019
    Red Deer Alberta
    katy's Tools
    I remember seeing similar on Sherman tanks in the 1950s.
    Apr 2012
    NorCal
    Saltfever's Tools
    Two different diameter tires! So only ONE axle is driven and the other is idling??
    Most probably, either that or they have 2 different rear end ratios or the poor power divider is getting a real work out. One possibility is since the tracks there would be no need to ever lock in the power divider undersized tires may have been installed on 1 axle to achieve a lower final drive ratio without having to change the rear ends
    Saltfever (Oct 11, 2022)
