Results 1 to 10 of 12
Thread: Nut centering tool for welding
    Jyväskylä Finland
    Tuomas's Tools
    First
    I know, there is weldable nuts.
    But, those need accurate hole where to be installed.
    Sometimes fitting takes a lot of time, still its possible that result is off centered.
    So, i made this tool.
    Idea is simple.
    Cone shape centers nut.
    When tool is tightened, it also clamps nut to its place.
    Material is copper, it prevents nut, or splatters to weld on to the tool itself. It also works as a backing, keeping threads of the nut in shape. If temperature rises too high.
    No need to chase threads after welding. ( Unless welds are messed up really bad )
  2. The Following 22 Users Say Thank You to Tuomas For This Useful Post:
    Andyt (Feb 6, 2021), baja (Feb 6, 2021), bobs409 (Mar 16, 2021), DIYer (Feb 8, 2021), floyd_kenny (Nov 8, 2022), HobieDave (Jun 21, 2021), IAMSatisfied (Feb 5, 2021), jimfols (Feb 7, 2021), Jon (Feb 5, 2021), lassab999 (Nov 9, 2022), Metallurg33 (Nov 9, 2023), Moby Duck (Feb 8, 2021), NortonDommi (Feb 5, 2021), Philip Davies (Feb 12, 2021), Ralphxyz (Feb 5, 2021), rdarrylb (Feb 6, 2021), rebuilder1954 (Feb 6, 2021), RetiredFAE (Nov 8, 2022), Sleykin (Feb 5, 2021), Toolmaker51 (Feb 7, 2021), trevor_60_r (Nov 9, 2022), verticalmurph (Nov 9, 2023)
    Jul 2014
    North Island, New Zealand.
    NortonDommi's Tools
    Nice. Many mechanics make a similar tool for weld-on hydraulic fittings that has a turned down section at the end that is thread root diameter for locating the fitting nice and straight to the hole. If not Copper they need to be sprayed with anti-spatter and removed toot sweet after tacking.
  4. The Following 2 Users Say Thank You to NortonDommi For This Useful Post:
    Moby Duck (Feb 8, 2021), Tuomas (Feb 6, 2021)
    Dec 2016
    Ralphxyz's Tools
    Do you have other sizes?
    Ralph
    Jun 2018
    Louisiana
    Good idea....brass I have copper I dont
    Jyväskylä Finland
    Tuomas's Tools
    Ralph
    M8 and M10 i haven't needed other sizes.
    Jyväskylä Finland
    Tuomas's Tools
    Quote Originally Posted by TrickieDickie View Post
    Brass works too.
  9. #7
    Brass works too.
    For solid material, at considerable cost saving too.
    I wonder, if de-funding will create surplus or shortage of coppers.........
  10. #8
    Thanks Tuomas! We've added your Nut Centering Tool for Welding to our Welding category,
  11. #9
    Supporting Member trevor_60_r's Avatar
    Nov 2019
    Queensland, Australia
    trevor_60_r's Tools
    Center nut in hole for tackwelding
    Hi Guys, in the past I have used Hex Socket Countersunk Screws to tack them in place with a small bit of never seize on thread and removed them before welding, as the nut can shrink on the screw.
    Name:  Countersunk screw.jpeg
    Thanks Trevor
  12. #10
    Flathead/ Countersunk screws have potential for centering, if the receiving hole has equal angle (ie deburring). Some try to use countersunk holes as locators (like dowels) with misconception the angle performs to draw an item this way and that. Unlike Tuomas's screw which was machined (if in one chucking) will be concentric. Flat head screws despite looking the same are not, therefore rarely share a common axis.
    It's easy to prove. Fabricate a plate with 3 countersunk holes inline or triangular pattern, matching 3 flat head screws, even sockets, which are closest.
    Run the screws in and number them with felt tip. Locate the position accurately, via dial indicator, height gauge, depth mic whatever you have. Remove the screws and place in different positions than previously and re-measure. Another demonstration is multiple screws tried in a single hole, Clamp plate vertically, touch with an indicator and turn in a succession of screws; the plate will rise and fall as countersink contacts underside of head.
    Part of reason aircraft screws are 100° not 82° reduces head height, = thinner material, hence lesser weight. Another is that concentricity problem, raising a point of stress in said panel, that the increased angle and shallower hole moderate.
    For most things, the flathead screw will perform as you wish. Just be aware, assembly time, some tuning might be in order.
