Results 1 to 5 of 5
Thread: Nut-and-bolt combination lock - GIF
    clydeman (May 14, 2024), nova_robotics (May 18, 2024)
    Aug 2019
    Oregon, USA
    BuffaloJohn's Tools
    So - 6*6*6 = 216 combinations - you can pick that lock by trying all the combinations in under 5 minutes and with a little knowledge, under 20 seconds...
    Biggest thing it has going for it is nobody expects 3 nuts with numbers...
    Nov 2012
    Phoenix, AZ
    rgsparber's Tools
    Pull the lever and rotate each bolt until there is no drag.
    Rick
    olderdan's Tools
    The same trick applies to most combination locks such as bicycle and key safes even as a young lad I could open those in a minute.
    Jul 2018
    Flora, MS
    Floradawg's Tools
    I thought about a way to make a safe or lockbox with a solenoid operated lock. 10 SPST push button switches in series with a battery and proper solenoid. Three or four n/o switches and the rest n/c. All n/o switches would have to be made and none of the n/c switches. All the switches of course would need to look identical. If any one of the n/c switches was made it would open the circuit and the solenoid would not be energized.
