Page 2 of 2 FirstFirst 1 2
Results 11 to 19 of 19
Thread: Nonius 1/40 an Drehmaschinen Oberschlitten.
    Great, I've just sent over the $100 award via PayPal. Congrats again
  2. #12
    Supporting Member Occasional machinist's Avatar
    Sep 2022
    Occasional machinist's Tools
    For me, the best bit is the use of PCB material to make it - quite a novel way to get around the problems of making one conventionally. Accuracy will be good because those things are done to quite fine tolerances.
    Michael
  3. The Following User Says Thank You to Occasional machinist For This Useful Post:
    mwmkravchenko (Jan 9, 2023)
  4. #13
    Perth Ontario Canada
    Quote Originally Posted by Occasional machinist View Post
    Michael
    Incredibly cheap and you can do black masking with white inlay.
  5. #14
    Apr 2013
    Nonius: A delightful little word with great history.
    https://en.wikipedia.org/wiki/Nonius_(device)
    Also a great word for Scrabble, and other esoteric language games.
  6. #15
    Sep 2021
    bigal001's Tools
    Many thanks for the idea...obviously this works on other lathes which have identical radii ( from pivot to scale )...what are the maths behind these calculations ...how was the Vernier established?
  7. #16
    Supporting Member 2gsg2_muc's Avatar
    Aug 2021
    Munich
    2gsg2_muc's Tools
    Well the calculations are very simple, just calulate the perimeter by PHI and then draw a line with that length, which you have to devide it by 360 to receive the distance from one mark to the next, which gives you a ruler for the diameter for the circle in degrees. Next draw a line from the center a line fro the over the radius an arrange this line from the center by 360 parts, so you receive a division of 360 by 1°. Draw a second circle which is larger tha the first one, now you can shorten the lines from the center to the first circuit, next shorten the overhanging lines to the second circle. This way you receive a ring with 360 short lines arranged along the circle.
    For more Information for calculating you can check at Wikipedia homepage.
  8. #17
    Sep 2021
    bigal001's Tools
    thanks ! will try it...
  9. #18
    Thanks Occasional machinist! We've added your Mill Vernier Scale to our Measuring and Marking category,
    as well as to your builder page: Occasional machinist's Homemade Tools. Your receipt:
  10. #19
    Aug 2021
    Munich
    2gsg2_muc's Tools
    Hi,
    I just received the new scales, I ordered due to wrong marking and changed them at my lathe.
    Nonius 1/40 an Drehmaschinen Oberschlitten.-kreisnonius-links.jpgNonius 1/40 an Drehmaschinen Oberschlitten.-kreisnonius-mitte.jpgNonius 1/40 an Drehmaschinen Oberschlitten.-kreinonius-rechts.jpgNonius 1/40 an Drehmaschinen Oberschlitten.-kreisnonius-front.jpg
