Results 1 to 9 of 9
Thread: No Carb here Semi drag racing
    If you love diesel smoke then watch this
    some of these trucks are making close to 3000 hp
    Altair (Mar 13, 2023), greenie (Mar 12, 2023), Inner (Mar 13, 2023), nova_robotics (Mar 13, 2023)
    greenie's Avatar
    Dec 2018
    greenie's Tools
    Got me beat how the clutch, engine mounts, gearbox, tail shaft, universal joints and diff centres stand up to that lot, eh. :-)
    Quote Originally Posted by greenie View Post
    For one you let out the clutch before pounding the floorboard with your right foot. If you heard that one guy mention he had a real low idle. Part of the reason for that is if he is putting out 2900 Hp at full RPM then he would be putting out around 400 to 500 at idle with 1600 ftlb. torque by the time the engine reaches 1200 it would be putting out around 3500ftlb.torque and max torque would come in around 1400 RPM. I've seen guys with 18 axle rigs weighing 160K lbs twist the yolks off drive shafts dumping their clutch at 1200 RPM with only 550 HP. Or pull the nose cone completely off the front diff. with less than 350HP Hot dogers break trucks
    greenie's Avatar
    Dec 2018
    greenie's Tools
    They are still putting out way more power than a normal drive-line could ever take, what are they using so there are NO breakages ?
    Dec 2022
    Midwest US
    ductape's Tools
    A lot of experience and a little bit of luck.
    Supporting Member bob_3000's Avatar
    Aug 2020
    Not in the video I'm watching, those guys have them revved to almost maximum before the tree turns green.
  8. #7
    Sep 2018
    nova_robotics's Tools
    Man that's amazing. I can't believe how it twists the whole frame. That's enough torque to restart a dead planet.
  9. #8
    Or if you strap one of them down facing the wrong direction it might stop the planet from rotating
  10. #9
    Supporting Member schuylergrace's Avatar
    Sep 2020
    Mesa, Arizona
    That strip is nuts! Imagine going over that hill at 100+mph at the end of a run. I assume 200mph cars don't run there.
    For topical application, only. Not to be taken internally or used in com-
    bination with other drugs or alcohol, except as directed by your shaman.
    Do not operate heavy equipment, unless you actually know how to.
