Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 21 to 30 of 33
Thread: NHRA Funny Car engine explosion
  1. #21
    Mar 2012
    If you look at the video frame-by-frame there are several frames where you look down thru the cylinders of the block as it spins. Where one normally expects to see pistons and crank a view of the white and red of the hood show up clearly. I am assuming said pistons and crank exited the vehicle with a similar velocity (Newton's third law or something like that) in the opposite direction of the block. We don't see them because the vehicle probably drove over it (probably some number of Murphy's law).
    I counted 4 turbos. Two at the very back that seem to have be in parallel feeding two more that seem to be in series. I have heard of systems like that with a claimed 100+ psi at the intake manifold.
  2. The Following User Says Thank You to arvidj For This Useful Post:
    PJs (Dec 27, 2018)
  3. #22
    PJs
    PJs is offline
    Sep 2014
    Northern CA
    PJs's Tools
    Quote Originally Posted by arvidj View Post
    Absolutely right about the 4 turbo's but the block was pretty muddy video to see that the cylinders were empty although whiteish. Interesting to see how it came apart and what stayed together considering a possible 100+psi...Wow! Strapping oneself into a bomb...Pass, not the right physics for me let a lone a Murphy number!
    Mark Twain
  4. #23
    Supporting Member Radioman's Avatar
    Jun 2018
    Massachusetts
    Radioman's Tools
    What we’re looking at is the upper half of the engine. The crank, rods and pistons are still bolted to the transmission. The block split at the base of the cylinders. An amazing failure. At least that’s how I see it. At first I thought the row of cylinder holes Wes where the head bolted on but it is where the rods and pistons go in after coming off the crank.
  5. The Following User Says Thank You to Radioman For This Useful Post:
    PJs (Dec 30, 2018)
  6. #24
    Apr 2016
    raido man may be correct, that may be the bottom portion of the block.Ive seen a few that broke out all the mains, but never seen a movie so exciting,stuff flying,smoke and tumbling. there are a few vid's of engines exploding similuar to this on eue tube....or is the oops tube... I see what looks like 3 turbos. the one I worked on at bristol had 2 1 big(the bigest Ive ever seen on a road vehicle) feeding a tiny turbo. I wonder just that the turbine speed was in the tiny turbo....
  7. #25
  8. The Following 2 Users Say Thank You to Jon For This Useful Post:
    PJs (Jan 5, 2019), Tule (Sep 21, 2019)
  9. #26
    PJs
    PJs is offline
    Sep 2014
    Northern CA
    PJs's Tools
    Surprisingly not very loud when it went off...and glad the driver didn't take a rod to the chin based on the damage to the top of the cab.
    Mark Twain
  10. #27
  11. The Following User Says Thank You to Jon For This Useful Post:
    Seedtick (Feb 26, 2019)
  12. #28
    bruce.desertrat's Tools
    And THAT is why Don Garlits developed the rear-engined top fuel dragster...
  13. #29
  14. The Following 4 Users Say Thank You to Jon For This Useful Post:
    Andyt (Sep 21, 2019), baja (Sep 22, 2019), Seedtick (Sep 20, 2019), Tule (Sep 21, 2019)
  15. #30
    <source src="https://diqn32j8nouaz.cloudfront.net/black_sheep_pulling_semi_blowup.mp4" type="video/mp4">
    </video>
    Prime example of packing too much power into the engine.
