Results 1 to 7 of 7
Thread: NHL ice rink removal - GIF
    May 2024
    Inner (Dec 17, 2024)
    Aug 2012
    Australia
    desbromilow's Tools
    why? is it to change the markings for the next use of the rink? or some other reason?
    Supporting Member odd one's Avatar
    Apr 2020
    WNC
    odd one's Tools
    Quote Originally Posted by desbromilow View Post
    Probably a multi-use arena.
    hemmjo's Tools
    They must be doing some graphics changes. Takes too much time and too much energy to melt and refreeze the ice between each change of event.
    The Ohio State University, Schottenstein Center is a multipurpose purpose arena. 2 1/2 hours is record time for ice rink to basketball conversion which typically takes 3 1/2 hours. The time for Ice rink to basketball is typically 4 1/2 . The ice is under the basketball floor. It stays there all hockey season.
    Time lapse Basketball to Hockey then back to BB. They also have monster trucks in there, I do not see video of that conversion.
  6. The Following User Says Thank You to hemmjo For This Useful Post:
    odd one (Dec 23, 2024)
    Supporting Member thevillageinn's Avatar
    Jul 2017
    thevillageinn's Tools
    That would be at the Honda Center in Anaheim, CA and it is a multi use arena.
    https://en.m.wikipedia.org/wiki/Honda_Center
    May 2021
    Vancouver, Washington, USA
    I worked at an ice arena back in high school. We were a multi-use facility with two rinks. We had an insulated floor that we'd lay down over the ice for non-skating events. I helped one weekend when we had to cut the ice down to nothing to repair leaks (we used red glycol so leaks were readily visible under the ice). It was a lot if work putting the ice back down. We sprayed a standard fire hose nozzle high into the air so the water would shed heat as it fell and thus, would freeze quicker once it hit the glycol coils that were bedded into sand under the ice. This process takes hours. Plus, after a certain point you start taking cuts with the Zamboni to ensure a proper, flat, smooth, finish. Plus, we had to repaint all of the lines after we repaired things. That was in 1978.
  9. #7
    Mar 2018
    Too bad there are so many more basketball fans than hockey fans. I go to hockey games but you couldn't drag me to a basketball game even if you paid me!
    "This country was founded by a bunch of slave owners that told us all men are created equal..." - George Carlin
