Think of it as really super high tech tig welding yes you are correct much like gas welding which is a kin to the same process as tig welding only you are using a flame torch instead of one that produces an arc. but then again I personally watched a man cut a Prince Albert tobacco can apart with a oxy act torch then weld it back together with the same torch only with a very small brazing tip and a piece of mechanics wire. I used to be good as far down as car fenders but never as thin as a tobacco can.
