Results 1 to 10 of 19
Thread: Nail removing gun - GIF
  2. The Following 9 Users Say Thank You to Jon For This Useful Post:
    baja (Feb 10, 2019), HobieDave (Apr 5, 2020), Miloslav (Nov 25, 2019), ranald (Feb 8, 2019), rlm98253 (Feb 8, 2019), Scotsman Hosie (Apr 5, 2019), Scotty1 (Feb 8, 2019), Seedtick (Feb 8, 2019), that_other_guy (Feb 18, 2019)
    PDXsparky's Avatar
    Nov 2018
    I’d like to know how that was made.
    Quote Originally Posted by PDXsparky View Post
    Fromthe looks of it the thing is nothing more than a standard nail gun without the feed and with a slightly different shaped nose and striker that allows the tool to be placed over the protruding nail point.
    Pretty useless tool for most things, actually as you still would need to first remove the board with a pry bar then make sure the nails were straight enough for the nose to slip over the nail.
    Might work fine for #6 to #8 finishing nails in trim boards but I would imagine you would need 2 or 3 different sized noses for larger nails if it would even have the power to drive framing sized nails out of 2x4's
    Plus there is the fact that each nail shot out of the lumber becomes potentially lethal or at the very least injurious projectiles
    PJs (Feb 9, 2019)
    Apparently pneumatic, otherwise like a lock cylinder punch. Piercing through the wood, instead of prying from opposite side, after driving with hammer. Useless to some, others who reclaim material in volume, might find this helpful.
    However;
    I didn't see any reference to wood thickness, I expect the general use is on 2" lumber. Their site text is poorly drafted, repetitive, lacks effective proof-reading.
    It's a perfect example what I call "long listing"; extolling obvious but questionable virtues.
    Anyone of us could stick a nail-sized rod in a tube and whack with a hammer, accomplishing same effect, probably close to same rate per minute. It would also be more compact, portable, save lugging compressor, and save $50+ for a real tool...Compared to long-listing, those aren't imaginary benefits.
    A more useful tool already exists, that drives individual nails, to clinch foot and head of close spaced cripples, near door frames, and frequently corners of stick frame construction.
    It's a long tube, ID accepts head of 16d or 20d nails, a rod with a striking head...a simple design.
    I'd find a small ID tube with a thick enough wall to notch a 'loading port' to save fully withdrawing the drive rod. Visualize a single shot bolt action rifle. An alternative would reinforce area around port with a close fitting sleeve.
  7. The Following User Says Thank You to Toolmaker51 For This Useful Post:
    PJs (Feb 9, 2019)
    Dec 2016
    Very similar to a pneumatic pop rivet gun.
    PDXsparky's Avatar
    Nov 2018
    Quote Originally Posted by owen moore View Post
    That’s what I initially thought, but don’t pop rivets work by pulling the pin out rather than push the pin in?
    If I was going to use something like that, it would be over a container to catch the nails that are expelled from the work.
  10. #7
    PDXsparky's Avatar
    Nov 2018
    I have used the tool you described to attach baseboard heaters to walls.
  11. #8
    Ahhh HAH! My IIRC was right for once? They were popular for quite some time, haven't seen one for quite some time. Maybe next company awaits expiration of patent.
  12. #9
  13. The Following 4 Users Say Thank You to Jon For This Useful Post:
    Alan Purdy (Feb 24, 2019), Andyt (Feb 19, 2019), Seedtick (Feb 18, 2019), that_other_guy (Feb 18, 2019)
  14. #10
    PDXsparky's Avatar
    Nov 2018
    Holy crap that machine is almost scary, but still really cool.
