Results 11 to 20 of 30
Thread: Mystery tools
    Hay Knife
    Quote Originally Posted by suther51 View Post
    Ps search "hay knife" in Google images
    Eric
    That is just exactly what it is.
  2. #12
    Jun 2018
    #1 is a hay/ice saw.
    Jan 2018
    Black Mountain Queensland
    ranald's Tools
    Hi Bony, looks like you have the answer to No.1 (I thought it was bart simpsons hair brush).
    If you don't get a full answer to no.2 , You could try the guys at The Traditional Tools Group Inc.(I think you are on the right track for welding pipes in situ.) If there is a makers mark it will be a lot easier. if those guys(TTTGI) want to charge, You can try searching via the "Australian Woodsmith" who often answer such queries via TTTGI.
    Good luck
  4. The Following User Says Thank You to ranald For This Useful Post:
    Toolmaker51 (Jun 19, 2023)
  5. #14
    Jun 2018
    Number two
    Quote Originally Posted by Bony View Post
    Attachment 25312
    Number one. I think it's used for cutting peat.
    Attachment 25313
    Number two. Possibly intended to manipulate pipes into place for joining lengths together when laying pipelines?
    I don't have any further info as I've been asked about the items I haven't actually seen them.
    If you actually know please share, although I'd prefer not have hundreds of guesses.
    Bony
    Number two looks like it was used as a clamp for taking the bow out of deck boards. The two pins would jam on the edge of a joist as the clamp pushes against the deck boards and the handle would lay across the other joist.
  6. #15
    Supporting Member Priemsy's Avatar
    I know number 1 as a silage cutter here in Aus.
  7. #16
    Jan 2018
    ranald's Tools
    At first sight I also thought that but the height adjustment did not seem to gel.
  8. #17
    Aug 2016
    No 1 is a hay knife
    No 2 is a flooring cramp for closing up the gaps between floorboards when laying a timber floor. The two pins straddle the floor joist and the screw bears on the side of the floorboards
  9. The Following 2 Users Say Thank You to Schtimpy For This Useful Post:
    Jon (Aug 28, 2018), suther51 (Aug 29, 2018)
  10. #18
    Jan 2016
    Southern tip of Vancouver Island
    I'd find a use for #2 as an alignment tool, or for a particular misalignment. Supports on the distal end of the parts would be needed. Many other ways to do that, though.
  11. #19
    bigtrev8xl's Avatar
    Jul 2016
  12. The Following 2 Users Say Thank You to bigtrev8xl For This Useful Post:
    ranald (Aug 29, 2018), Toolmaker51 (Jun 19, 2023)
  13. #20
    Aug 2016
    Uitvinder's Tools
    Attachment 25312
    Attachment 25313
    Bony
    Tool number one is a hay saw.
    Just to cut big hay bales into smaller pieces.
