Results 1 to 10 of 11
Thread: Mystery rod shuffling machine - GIF
    Mystery (at least to me), labeled "rod shuffling machine". Anyone?
    olderdan (Dec 12, 2018), PJs (Dec 13, 2018), Seedtick (Dec 12, 2018)
    olderdan's Tools
    It would seem to me not so much shuffling as separately transporting to another stage of processing in a controlled manner.
  4. The Following User Says Thank You to olderdan For This Useful Post:
    PJs (Dec 13, 2018)
    It could be an artifact of Chinese-to-English translation. Whatever the Chinese verb was, it was translated into "shuffling" in the connotation of "moving forward in very small steps".
    May 2015
    Sorry guys, close but no cigar. This is a walking beam conveyor. In this case used at the end of a rod rolling mill. The rod would come out red hot and pliable and be gradually air cooled on the walking beam conveyor until gray (cold). Every rod mill usually uses them when straight rod is required. e.g., rebar mills.
  7. The Following 4 Users Say Thank You to jcorpx For This Useful Post:
    Miloslav (Dec 15, 2018), PJs (Dec 13, 2018), that_other_guy (Dec 15, 2018), Toolmaker51 (Dec 15, 2018)
    Aug 2016
    wizard69's Tools
    Jcorpx has it. If you look real closely you can see a new rod enter the buffer once every cycle. I say buffer because on a smaller scale I’ve seen similar mechanisms used to buffer product from one state to the next.
    Dec 2016
    Same mechanism used in hot work conveyors and even some hay balers. I designed one years ago for a transport conveyor in a cafeteria that would move any kind of dish, plate, or glass from point A to point B. My walking beams were smooth instead of saw tooth in design. The one pictured appears to be powered in a true rotary fashion. I used a rectilinear motion for a short lift, but more travel per stroke.
  10. The Following 2 Users Say Thank You to owen moore For This Useful Post:
    PJs (Dec 13, 2018), Toolmaker51 (Dec 15, 2018)
  11. #7
    Dec 2015
    Reading, Berks, UK
    Philip Davies's Tools
    Anybody else suffering from motion sickness?
  12. #8
    May 2018
    Boring, OR
    CharlesWaugh's Tools
    The same process is used in a local steel mill to move multiple 10,000 pound blocks of steel through the furnace prior to being rolled into plate stock.
    The hydraulic cylinders that run the 'floor' are 3' in diameter and run at 4200PSI.
    Charles Waugh
    www.charleswaugh.com
  13. #9
    Agreed, walking conveyor is most likely. Infeed of bar stock defines it; though my first impulse was handling bar during manufacture of cat walk flooring. Excess length was a vote against it.
  14. #10
    Looks like a walking cooling bed in a rebar mill.
