Thread: Mystery construction process - GIF
    nova_robotics (Jun 15, 2024), tuchie (Jun 11, 2024)
    No real mystery here this is vertical trenching, The reasons for this is they are planning on construction a tall building but first even before excavation for the footing or basement levels can be done the foundation and footing of the adjacent building must be protected the water slurry being pumped in maintains some pressure in the cavity as it is being excavated when the prescribed depth is obtained a steel framework of rebar will be lowered then concrete will be pumped via hoes which will be lowered to the bottom and raised as the concrete level rises once the concrete has set up enough to remain in place the next trench will be excavated until a barrier has been poured all the way around the perimeter of the new building Some of these vertical trenches can reach 60 to 100 feet in depth depending on how far down it is to bedrock
  4. The Following 13 Users Say Thank You to Frank S For This Useful Post:
    baja (Jun 16, 2024), Floradawg (Jun 11, 2024), hemmjo (Jun 11, 2024), Inner (Jun 11, 2024), Jon (Jun 10, 2024), Karl_H (Jun 11, 2024), KustomsbyKent (Jun 11, 2024), mr mikey (Jun 11, 2024), neilbourjaily (Jun 20, 2024), nova_robotics (Jun 15, 2024), Ralphxyz (Jun 12, 2024), schuylergrace (Jun 11, 2024), tuchie (Jun 11, 2024)
    Jul 2018
    Flora, MS
    Floradawg's Tools
    While I was watching that I figured if anyone knew what was going on it would be Frank S.
  6. The Following 3 Users Say Thank You to Floradawg For This Useful Post:
    baja (Jun 16, 2024), Duke_of_URL (Jun 12, 2024), Frank S (Jun 12, 2024)
