Results 1 to 7 of 7
Thread: My own vibratory tumbler.
    engineerd3d's Avatar
    Dec 2018
    engineerd3d's Tools
    I figured I would make a vibratory tumbler. Cost was very low and some shop time. I will be improving the design at some point but so far I have been using this thing with good success.
    Here is a video of its construction.
  2. The Following 4 Users Say Thank You to engineerd3d For This Useful Post:
    David Johnson (Jan 22, 2019), mwmkravchenko (Jan 21, 2019), PJs (Jan 22, 2019), Seedtick (Jan 21, 2019)
    So did you damage 1 of the vanes oon the muffin fan to mage it out of balance?
    I have several of them running around the house silently moving air and none of them show the least bit of vibrations
    Nice one. About a year ago I planned to build something similar but I did not think that I had a suitable motor and I built a rotary tumbler instead. I have a ton of those computer fans but it never occurred to me to use one of those.
    I also have the same question as Frank S regarding balance and vibration.
    My rotary tumbler is very noisy and I might revisit a vibratory version like yours.
    Dec 2018
    engineerd3d's Tools
    The fan was set out of balance using a nut/bolt through one of the blades, the plate ontop is to reduce drag in the fan by blocking airflow. This thing is fairly silent. If you notice the spool was used as a spring as well. This design has 4 dampening sections. Feet/first level spool/second level spool/springs. The result is that even in a hard surface there is no resonance at all.
  6. The Following User Says Thank You to engineerd3d For This Useful Post:
    PJs (Jan 22, 2019)
    hemmjo's Tools
    You can see the screw and nut at about 12:17 in the video
  8. The Following User Says Thank You to hemmjo For This Useful Post:
    PJs (Jan 22, 2019)
    Thanks engineerd3d! We've added your Vibratory Tumbler to our Miscellaneous category,
    as well as to your builder page: engineerd3d's Homemade Tools. Your receipt:
  10. #7
    Dec 2018
    engineerd3d's Tools
    Thank you for giving me my own builder page. It's awesome!
