Results 1 to 7 of 7
Thread: Multifunction workstation / Part 1: furniture and cooling system
    Oct 2017
    Eloy Workshop's Tools
    Hello everyone!!!
    This is the first video of a quite complete project, where I will make many accessories for the vertical drill and I will try to make the most of it.
    In this first video you will see how to take advantage of a scrap of a beam to use it as a piece of furniture, the front is equipped with drawers to store the bits and accessories of the drill, the front is stamped where we can see what each drawer contains.
    In the back I have a tank of taladrina (the taladrina is used to cool and lubricate the machining of metal parts) inside this deposit we find a pump of 12V that will drive the taladrina through a flexible tube, the return will fall to the container and will go down the return pipe to a filter housed inside the tank, with this we will try to retain all the metal shavings.
    For the regulation of the flow of the coolant, I have installed a speed regulator in addition to a switch where we can change the direction of rotation in case of blockage, the control panel is housed in the upper part of the furniture of the vertical drill.
  2. The Following 4 Users Say Thank You to Eloy Workshop For This Useful Post:
    NortonDommi (Nov 29, 2017), rlm98253 (Nov 26, 2017), Seedtick (Nov 26, 2017), Tuomas (Nov 28, 2017)
    Apr 2017
    Very, Very impressive and functional. I also liked the vise (never seen before) looks very rugged and functional also . It's a lot of work. Wonder
    why no one else hasn't put one on the market. Thanks AL
    Thanks Eloy Workshop! We've added your Drill Press Cooling System Catch Tray to our Drilling and Drill Presses category,
    as well as to your builder page: Eloy Workshop's Homemade Tools. Your receipt:
    Thanks Eloy Workshop! We've added your Drill Press Cooling System to our Drilling and Drill Presses category,
    Oct 2017
    Quote Originally Posted by hilerioal@outlook.com View Post
    Thank you very much friend, the truth that has been very well and the best comes in the second part ajajjajaja I hope it goes well, because to take what you have in your head to real life ... sometimes it is very complicated
    Regards!!
    Oct 2017
    <div id="blocks"> <div class="block b1 pngfix"> <div class="bimg"> <div> <a href="http://www.homemadetools.net/homemade-drill-press-cooling-system-catch-tray"> <img src="/uploads/207460/homemade-drill-press-cooling-system-catch-tray.jpeg"/> </a> </div> </div> <div class="head pngfix"></div> <div class="left pngfix"></div> <div class="right pngfix"></div> <div class="blockover b1 pngfix"> <div class="title"> <a href="http://www.homemadetools.net/homemade-drill-press-cooling-system-catch-tray">Drill Press Cooling System Catch Tray</a> <span> by <a href="http://www.homemadetools.net/builder/Eloy+Workshop">Eloy Workshop</a></span> </div> <div class="tags">tags: <a href='http://www.homemadetools.net/tag/drill-press'>drill press</a>, <a href='http://www.homemadetools.net/tag/coolant'>coolant</a> </div> </div> </div> </div>
    Well thank you very much for helping me, I appreciate it, to see if little by little I understand the web better, because I think there are different sections.
    thank you very much for everything and regards!
  8. #7
    Oct 2017
    [QUOTE=DIYer;102970]<!-- BEGIN /var/www/html/homemadetools/protected/modules/zeus/views/tool/postUpdate.php -->
