Results 1 to 5 of 5
Thread: Multifuction track guide circular saw & trim router with self clamp
    Supporting Member Didpoolhall's Avatar
    Feb 2019
    indonesia
    Didpoolhall's Tools
    build simple but accurate track guide. you can use for circular saw or trim router. Cut use circular with this track very accurate and you not worry about the blade depth, you can use maximum blade depth
    very easy for build but very help for work precision.
  2. The Following User Says Thank You to Didpoolhall For This Useful Post:
    Jon (Jul 1, 2021)
    Jun 2021
    Where can I get the exact plans to build this? This looks great and appears simple, but need measurements in inches, not MM.
    Thanks Didpoolhall! We've added your Multifunction Track Guide to our Jigs category,
    as well as to your builder page: Didpoolhall's Homemade Tools. Your receipt:
    Apr 2020
    multiply mm by 25.4 to get inches
    Quote Originally Posted by jmart235 View Post
    or, if you want the correct answer, DIVIDE mm by 25.4 to get inches.
