Originally Posted by
RetiredFAE
I had a 1936 Rockwell Delta 16" drill press that never had the rack and pinion table lift, I put a Harbor Freight 1.5 ton long ram flat base hydraulic jack under the table, quick disconnect mount on the table and the floor base so it can be removed for really tall workpieces.
Slow to raise and lower the table until I rigged a foot pedal and a pressure relief valve that I didn't have to bend down to actuate either of them.
Think I like the above idea of the pulley arrangement with a counterweight better!
