Results 1 to 6 of 6
Thread: Motorized & Automatic Plasma Cutting Linear Guide
    Supporting Member darus627's Avatar
    Jan 2017
    Poland
    darus627's Tools
    Using a 12V car wiper motor, I decided to make an automatic track for cutting steel sheets.
    The elements used are:
    12V wiper motor (I think Volkswagen)
    Toothed belt 10 T5
    2 gears 27-T5-10
    4 Linear Shaft End Bracket SK16
    2 Linear bearing in housing SMAG16UU
    2 Stainless guide shaft fi16 h6 130 cm long
    2 Self-aligning bearing KP08-8 mm
    Interestingly.
    The specification of my plasma cutter allows for a quality cut of 6 mm. In the video you can see how thanks to this tool I cut 10 mm sheet metal.
    Download plans for cnc plasma cutters.
  2. The Following 7 Users Say Thank You to darus627 For This Useful Post:
    fizzloid (Aug 9, 2023), Frank S (Aug 28, 2023), Jon (Aug 8, 2023), mr mikey (Aug 8, 2023), nova_robotics (Aug 8, 2023), Ralphxyz (Aug 11, 2023), schuylergrace (Aug 17, 2023)
    Thanks darus627! We've added your Plasma Cutter Guide to our Cutting Torches category,
    as well as to your builder page: darus627's Homemade Tools. Your receipt:
    Sep 2018
    nova_robotics's Tools
    Beauty. Can you put little felt wipers on either side of those linear bearings to help keep some of the crud out? They're probably going to get crunchy with all the slag.
    Dec 2016
    Ralphxyz's Tools
    Nice project. How did you join the belt?
    The belt was clamped, see 6:43 on the video
    Dec 2016
    Ralphxyz's Tools
    Duh, of course, Thanks.
