Results 1 to 4 of 4
Thread: Motorcycle wheel bearing remover
    Supporting Member Cascao's Avatar
    Brasil
    Cascao's Tools
    Thumbs up Motorcycle wheel bearing remover
    Made to allow centralized force be applied on bearings while removing.
    This bearing extractor have a conical hole wich expand when conical mandrel is inserted.
    Made this wheel bearing extractor in a rush, so don't be picky with weird saw cuts.
    The goal is to avoid bearing wobble when removing and hub damage.
  2. The Following 2 Users Say Thank You to Cascao For This Useful Post:
    Seedtick (Dec 4, 2017), sossol (Dec 5, 2017)
    Brasil
    Cascao's Tools
    Dimensions may vary. This one is for 6004 bearings
    Thanks Cascao! We've added your Wheel Bearing Extractor to our Motorcycle Wheel and Tire category,
    as well as to your builder page: Cascao's Homemade Tools. Your receipt:
    Supporting Member pfredX1's Avatar
    Sep 2016
    Delaware
    pfredX1's Tools
    You can pack the center with grease, then hammer a wooden dowel in the center hole to hydraulically press bearings out. It is an old pilot bearing trick.
