Results 1 to 5 of 5
Thread: motorcycle water pump impeller
    Supporting Member Cascao's Avatar
    Brasil
    Cascao's Tools
    The impeller of my motorcycle had better days...and shipping from france to brasil take too much time. So making one was the obvious choice.
    the impeller was made with a hex (used the hex as a indexer) aluminium bar in a milling attachment on my bench lathe. The impeller pattern was transfered from oem to part with ink and tape.
  2. The Following 5 Users Say Thank You to Cascao For This Useful Post:
    olderdan (Apr 25, 2018), PJs (Apr 28, 2018), Seedtick (Apr 26, 2018), thehomeengineer (Apr 25, 2018), Toolmaker51 (Apr 25, 2018)
    I like it and can reply with accomplishing a similar task in a like size.
    Mine is a lathe coolant pump. Also found at least .100 [2.5mm] excess clearance between housing, impeller and cap.
    Instead of chucking and facing cap in the 4-jaw, made impeller taller. More volume with little increase in pressure.
    Berkshire UK
    thehomeengineer's Tools
    Very nice fix and this should last longer and be better than the original pump impeller.
    olderdan's Tools
    Very nicely done and all in the lathe (my style).
  6. The Following User Says Thank You to olderdan For This Useful Post:
    PJs (Apr 28, 2018)
    Brasil
    Cascao's Tools
    The milling attachment had payed himself one more time....
