Thread: Motorcycle lift table for forklift
    Supporting Member Imabass's Avatar
    Dec 2015
    Imabass's Tools
    This is an amazing addition to my shop. I use this more than my other two motorcycle lift tables.
    Super high lift for easy access to the bottom of the engine.
    Adjustable for any height.
    I used about 8' of 10"x12# ibeam. I simply cut out for fork holes and welded a 2x2" front cross brace for stability on the ground as well as for tie down. There is also a 5/8 round rod that is welded to the front for a wheel stop. There are 3 wheels welded to the bottom to facilitate easy rolling around in the shop with a bike strapped down on the platform. I cut a large removable plate from the center for access to the oil pan and bottom side of the motorcycle.
    I typically use a piece of plywood that I can rest across the forks of the forklift that acts as a bench for resting tools and parts.
    Download plans for motorcycle lifts stands and dollies.
  2. The Following 9 Users Say Thank You to Imabass For This Useful Post:
    baja (Jul 18, 2019), freddo4 (Apr 26, 2023), Jon (Dec 7, 2015), kbalch (Dec 7, 2015), nova_robotics (Oct 13, 2022), Paul Jones (Dec 8, 2015), PJs (Dec 8, 2015), Tenn (Jul 17, 2019), Toolmaker51 (Aug 8, 2016)
    Thanks Imabass! We've added your Motorcycle Lift to our Motorcycle Lifts, Stands, and Dollies category, as well as to your builder page: Imabass's Homemade Tools. Your receipt:
    Dec 2017
    NeiljohnUK's Tools
    What mechanical safety device is there in case of forklift failure?
