Page 2 of 2 FirstFirst 1 2
Results 11 to 19 of 19
Thread: Modifying Socket Head Cap Screws
    Jul 2019
    Quote Originally Posted by Wmrra13 View Post
    Hi,
    Cool trick!
    How did you hold the bolts to do the center drilling? Put nuts on and held them in the 3-jaw?
    Thanks,
    Tyler
    Gee....over 2 years & still no answer to this question?🤔
  2. #12
    Quote Originally Posted by Wildwilly View Post
    Gee....over 2 years & still no answer to this question?��
    K.........I'll step in.
    Two nuts can work with issues.......so
    Scattered here at HMT.net are 'lantern chucks', and best over all solution.
    Next, with less initial labor.......
    Coupling nuts [the long type] are better, just back the hex or socket up against a solid stop to not back out when cutter takes hold.
    Or coupler nut in jaws with washer and lock nut in front. Good thing about nuts of course with hex bolts [HHCS] are same size, secure clamping and alignment. I keep handy at least two of any sizes I come across.
    Socket Head Cap Screws [SHCS] the nut and washer work.
    Or slip them in through back side of collet, in a collet block, chucked in jaws.
    Doing a lot? Pick collet larger than screw head, make a headed bushing with screw diameter, saw cut one side open, partially on the other. When it breaks or flub the cutting, the head continues to orient as it was made. Plus it's a handle to retrieve from chuck or collet.
    Or in mill, block in vise, just like above. Set a stop, dial in and go to town.
  3. The Following User Says Thank You to Toolmaker51 For This Useful Post:
    Wmrra13 (Jan 6, 2021)
  4. #13
    Supporting Member Wmrra13's Avatar
    Jan 2015
    Wmrra13's Tools
    Awesome, love the coupler nut idea, I use those things for various tasks around the shop.
    Thanks!
  5. The Following User Says Thank You to Wmrra13 For This Useful Post:
    Toolmaker51 (Jan 19, 2022)
  6. #14
    Supporting Member gatz's Avatar
    gatz's Tools
    I know what ya mean about “making your own”
    But, McMaster-Carr has something that would fit the bill right out of the box.
    https://www.mcmaster.com/fillister-head-machine-screws/length~3-8-2/thread-size~1-4-20/flanged-socket-head-screws/length~1-2-1/length
    The plus is that the hex remains the same as regular 1/4-20s
  7. The Following User Says Thank You to gatz For This Useful Post:
    Harvey Melvin Richards (Jan 19, 2022)
  8. #15
    Ahhhhhhhhh, McMaster-Carr....epic company and website light-years ahead of ANY other distributor - warehouser - and especially everyone's favorite but despicable go-to.
  9. #16
    hemmjo's Tools
    At $4 to $5 EACH, plus shipping, I like that idea of squandering an allen wrench, making a lantern chuck, or using two nuts, or any of the other good solutions.
    Yep, I am a cheap skate, and proud of it.
    PS. Actually, now that I think about it, I am pretty sure I could fit the short end of the wrench behind the jaws of my chuck. worst case would be to shorten it a little. Even better take one out of the folding set I carry in my portable tool box. I am positive the small looped would fit behind the chuck jaws.
  10. #17
    Oct 2015
    th62's Tools
    Good idea, probably not many have noticed but the head on cap screws is not concentric to the threaded shaft. If you chuck the threaded shaft and turn the lathe on, you'll find it is a little eccentric. I only noticed this when polishing the heads of Allen heads for my custom TX650.
  11. #18
    hemmjo's Tools
    Quote Originally Posted by th62 View Post
    After you use the socket to drive the screw to turn down and re-thread the screw, it will be concentric. As least within the tolerance of the fit of the wrench into the socket.
    I often use old or new bolts as stock to turn into other things I need. Chucking a clean bolt in a collet, I have discovered that neither the hex head or the threads are concentric with the shank on most bolts. I doubt it would cause any issues in most situations.
  12. #19
    Quote Originally Posted by bruce.desertrat View Post
    I have a metal canister full of perfectly good allen wrenches; I'm pretty sure they're multiplying in the darker recesses of my tool boxes :-) This is a neat hack.
    Old hex socket wrenches never die; can be easily ground if kept cool.
    Others with the ''L'' twisted become ''T'' extension wrench. Drill a hole of diameter equal to flats around 6 diameters deep into mild steel rod, press in shank, weld a T onto that rod.
    I've also set them in place with JB Weld, the fit needs to be rather snug and/ or deeper.
