Results 1 to 10 of 19
Thread: Modifying Socket Head Cap Screws
    Dec 2013
    Florida
    rossbotics's Tools
    A couple of posts back I submitted a tool called a V-Step Angle Plate, there were three clamps made especially for holding work to different places on the plate for grinding, there are a series of 1/4-20 holes tapped throughout the plate for attaching the three clamps, the clamps have 1/4” slots milled into them for making adjustments, I originally used 1/4” socket head cap screws for the slots which was ok but I soon found out that the heads on the screws were a little too small for me, I didn’t want to put washers under the heads of the screws so I decided to take 5/16” socket head cap screws and turn them down to 1/4" and rethread them, but holding the screws by their heads in the chuck limited me how far back I could machine them without running the cutting tools into the chuck, I wanted to turn them down all the way back to the head of the screws and machine cut the threads all the way as well, the only thing I could think was to cut the bend off of a 1/4" allen wrench and chuck up the allen wrench and let the wrench drive the screws while I did my machining, probably nothing new I’m sure but worked for me, but in the same token I destroyed a perfectly good allen wrench, oh well
    I have included some photos of the machining process
    As always thanks for looking and happy machining
    Doug
    Modifying Socket Head Cap Screws-1.jpg Modifying Socket Head Cap Screws-2.jpg
    Modifying Socket Head Cap Screws-3.jpg Modifying Socket Head Cap Screws-4.jpg
    Comments are always welcome
    Doug
  2. The Following 23 Users Say Thank You to rossbotics For This Useful Post:
    asterix (Jan 19, 2022), baja (Jan 6, 2021), bruce.desertrat (Jun 4, 2018), Bullet500 (Jan 19, 2022), Corm (Jun 5, 2018), Harvey Melvin Richards (Jan 19, 2022), johncg (Jan 19, 2022), mackai (Sep 2, 2024), natie123 (Jun 5, 2018), NortonDommi (Jun 5, 2018), nova_robotics (Jan 18, 2022), philipUsesWood&Brass (Jun 21, 2018), PJs (Jun 5, 2018), rgsparber (Aug 30, 2024), Seedtick (Jun 4, 2018), sossol (Jun 4, 2018), sparky42 (Jan 19, 2022), threesixesinarow (Jun 21, 2018), Toolmaker51 (Sep 1, 2024), tooly (Aug 15, 2023), Tule (Mar 22, 2019), UncleBob (Jun 16, 2018), Wmrra13 (Jan 11, 2019)
    Doug button head screws would have probably worked well for you their heads have a larger diameter than socket head
    Dec 2013
    Florida
    rossbotics's Tools
    You're right Frank, thought of that but you know how it is when you get your mind set on something, just wanted to use socket heads cause the rest of the hardware is, but could have changed them all to buttons.
    Doug
    Doug
  6. The Following User Says Thank You to rossbotics For This Useful Post:
    PJs (Jun 5, 2018)
    Supporting Member Kwick Aronson's Avatar
    Sep 2015
    Thumbs up
    Wow. I have a whole tub of Titanium Allen, Torx and hex discards from a bolt machining company.
    You just made my project of making odd motorcycle pivots and the like one heck of a lot easier.
    bruce.desertrat's Tools
    I have a metal canister full of perfectly good allen wrenches; I'm pretty sure they're multiplying in the darker recesses of my tool boxes :-) This is a neat hack.
    Thanks rossbotics! We've added your Allen Bolt Modification to our Machining category,
    as well as to your builder page: rossbotics's Homemade Tools. Your receipt:
  10. #7
    Dec 2016
    Ralphxyz's Tools
    Great idea, sure you can always buy something but you could even use larger screws, using the allen hex in the chuck was a great idea.
    Now how am I gonna remember this?
    Ralph
  11. #8
    PJs
    PJs is offline
    Sep 2014
    Northern CA
    PJs's Tools
    Quote Originally Posted by rossbotics View Post
    Doug
    Still a good trick using the 1/4" allen to drive it. Seems I tried this once and ran into a root diameter issue leaving a small void...but then again I once got chewed out for using a 1/4-28 instead of a 1/4-20 because I thought the engagement was critical to what I was doing and the difference in the cost of a box of them was <$1 at the time. Who knew it mattered @¿@, but then again I think Button heads are classy.
    Thanks Doug!
    Mark Twain
  12. #9
    Doug; a cut off hex wrench isn't wasted at all. Before T-handled hex wrenches, especially freakish long buzzards for machine repair, we did our own. Drill good quality rod closest possible size or .001 under hex size across flats, Square, chamfer and press a hex section in & bottomed out. Roughly speaking 10+ diameters depth will retain the hex indefinitely. I'll bet a couple from way back still hide out in a drawer somewhere.
  13. #10
    Supporting Member Wmrra13's Avatar
    Jan 2015
    Wmrra13's Tools
    Hi,
    Cool trick!
    How did you hold the bolts to do the center drilling? Put nuts on and held them in the 3-jaw?
    Thanks,
    Tyler
