Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 25
Thread: Modifying small screws
    Here's how I go about modifying the ends of small screws...
    A brass 'collet' is made for each size of screw by tapping a short slug of brass with the required thread and then milling a small flat on the slug. The screw is then threaded through the collet and secured in place with a lock nut. The collet is then inserted into a steel tube and locked in place with a set screw.
    The whole assembly is then stuck in a 5C collet on the lathe and the required work performed. (The picture shows a dog point put onto a 2-56 screw.)
    The brass "collets" are easy to make and, over time, you'll acquire a collection of them to fit the screw sizes you use most frequently. They're a handy use for the uselessly short bits left over from stock rods.
  2. The Following 17 Users Say Thank You to mklotz For This Useful Post:
    baja (Dec 13, 2019), benkeller3 (Oct 31, 2017), fourmdev (Mar 30, 2024), high-side (Dec 14, 2019), Home-PC (Mar 18, 2022), jere (Sep 1, 2015), Jon (Aug 29, 2015), kbalch (Aug 31, 2015), Moby Duck (Apr 5, 2018), mr mikey (Mar 30, 2024), Paul Jones (Sep 1, 2015), PJs (Sep 2, 2015), Ralphxyz (Mar 31, 2024), Raytonian (Sep 14, 2021), reysl1949 (Nov 17, 2020), rlm98253 (Nov 2, 2017), User Name (Feb 20, 2016)
    kbalch's Avatar
    Jun 2012
    Clermont, FL
    Thanks mklotz! I've added your Screw Modification Tool to our Lathe Accessories category, as well as to your builder page: mklotz's Homemade Tools. Your receipt:
    Another great idea, thanks.
    Supporting Member jere's Avatar
    Feb 2015
    jere's Tools
    very interesting, I have seen automotive engine head studs that require the dog point but what are you using such a small one for?
    Quote Originally Posted by jere View Post
    In this particular case it was for a working model of a WWII deck gun...
    http://www.homemadetools.net/forum/m...6438#post66433
  7. The Following 13 Users Say Thank You to mklotz For This Useful Post:
    C-Bag (Sep 7, 2015), Christophe Mineau (Sep 2, 2015), Home-PC (Mar 18, 2022), jere (Sep 1, 2015), kbalch (Sep 1, 2015), Moby Duck (Apr 4, 2024), mr mikey (Mar 30, 2024), oldcaptainrusty (Nov 1, 2017), olderdan (Nov 3, 2017), Paul Jones (Sep 1, 2015), PJs (Sep 2, 2015), Ralphxyz (Mar 31, 2024), Scotsman Hosie (Jul 12, 2023)
    kbalch's Avatar
    Jun 2012
    Clermont, FL
    What a fantastic piece! Absolutely awe-inspiring model making.
    Ken
  9. #7
    Feb 2015
    jere's Tools
    Ken said it better than I could! the "working " part really caught my attention too!
  10. #8
    Yes, the handwheels train and elevate the barrel, and the recoil absorber mechanisms all work as in the real thing. The barrel is made from a turned down .22 rifle barrel so it's fully rifled. The quick-lock, quarter-turn breech block is operated via the handle. The only thing that's unrealistic is the blocky structure on the breech block which contains the trigger mechanism and the firing lanyard.
    It can fire .22LR. However, we have five grandchildren so the firing pin is removable and hides in the dummy shell you can see in some of the pictures. [Real ammo is kept in a gun safe.]
    Here are a couple more pictures...
  11. The Following 7 Users Say Thank You to mklotz For This Useful Post:
    Home-PC (Mar 18, 2022), mr mikey (Mar 30, 2024), oldcaptainrusty (Nov 1, 2017), olderdan (Nov 3, 2017), PJs (Sep 2, 2015), Ralphxyz (Mar 31, 2024), Scotsman Hosie (Jul 12, 2023)
  12. #9
    kbalch's Avatar
    Jun 2012
    Clermont, FL
    What an incredible piece of work.
    Which specific model of deck gun was the inspiration? What scale did you use?
    Ken
  13. #10
    May 2014
    Del Mar, California
    Paul Jones's Tools
    Wow, your precise workmanship on this model is fantastic and having a working model takes it to yet another level. I found on your website the section for "Information Nuggets" very interesting. Looking forward to seeing more of your custom tools (and your model examples).
    Paul
