Thread: Modifying a Screw-in Lathe Backplate to fit on a small 3 bolt spindle - Mini Mill Dri
    Supporting Member theeddies's Avatar
    Mar 2019
    Georgia, US
    theeddies's Tools
  2. The Following User Says Thank You to theeddies For This Useful Post:
    Sleykin (Feb 8, 2020)
    Supporting Member Sleykin's Avatar
    Oct 2017
    Medford, Oregon USA
    Sleykin's Tools
    If you want your bolt circle to be concentric with the outside edge, I just use my center finder from the combination square. (The "V" shaped part) and use that to set for the depth of my inner circle and run a scribe around the disk using the end of the rule to guide me.
  4. The Following User Says Thank You to Sleykin For This Useful Post:
    theeddies (Feb 9, 2020)
    Mar 2019
    Georgia, US
    theeddies's Tools
    I felt like the casting was just a bit out of round to do that. It turned out that is was not that bad and I could have probably done that. Thanks
