Thread: Modified bending dies for 4" wide metal bender
    Dec 2014
    South Dakota
    KustomsbyKent's Tools
    I bought this 4" wide metal bending unit from Amazon... $125. Main use will be 1/8" and 1/4" thick mild steel, and 1" to 2" wide.
    The problem is that the dies that it showed up with are optimized to bend really thick material.... like up to 3/4" thick, not something I plan to do.
    So I made an insert for the "bottom" die, and sharpened up the "vee" point on the top die. I use top and bottom die like they would be configured in a hydraulic press brake for reference.
    I think this would be a good bender for many people to buy for making projects, low cost, easy to use, and decent capacity.
    The way I ended up mounting this, the wide open die (bottom die) is actually in the top on this piece of equipment.
    Here's a quick video:
  2. The Following User Says Thank You to KustomsbyKent For This Useful Post:
    piper184 (Jul 7, 2023)
    Thanks KustomsbyKent! We've added your Bender Die Modification to our Metalworking category,
    as well as to your builder page: KustomsbyKent's Homemade Tools. Your receipt:
    KustomsbyKent (Jul 6, 2023)
