Results 1 to 9 of 9
Thread: Mobile crane collapses while installing billboard, with possible dozer assist - GIF
    Mobile crane collapses and flips upward while installing or adjusting billboard. The real mystery here is what's going on with that dozer in the lower right? Were they using a dozer to counterweight a crane, and then something went wrong?
    https://www.homemadetools.net/forum/...209#post115950
    Heavy lift ring crane - video
    Ferry crashes into crane, crane explodes - GIF
    Motion compensating crane for moving cargo containers at sea - GIF
    Skid steer dangling from crane, breaking concrete - GIF
    cmarlow (Dec 25, 2018), ranald (Jan 10, 2019), rossbotics (Dec 26, 2018), Seedtick (Dec 26, 2018)
    bruce.desertrat's Tools
    Honestly it looks like they were lifting the front of the crane with it. Maybe the winch on the crane was jammed, and they were trying to lower the billboard the last few feet into place?
    No if you use the full screen you can see the loader bucket fall slightly after slipping off of the outrigger and breaks off the foot.
    It is also clear that they were removing the billboard as just before the calamity happens 2 guys can be seen casually descending the ladder.
    @7 axles this was no small crane 125 to 175 ton range at least.
    I also noticed that they had the boom extended way farther than needed. judging by the lay of the land I believe the cane could have been several feet closer even with the boom elevated all the way up as it was but retracted about 20 feet would have made all the difference in the world in making that pick. Plus a million dollar crane and a multi million dollar home or building would not have been damaged
    Toolmaker51 (Dec 26, 2018)
    Oct 2018
    What we have here is a failure to calculate.
  7. The Following 2 Users Say Thank You to cmarlow For This Useful Post:
    rossbotics (Dec 26, 2018), Toolmaker51 (Dec 26, 2018)
    Dec 2013
    Florida
    rossbotics's Tools
    Oh My !
    Doug
    Comments are always welcome
    Doug
    Oh you and your 36" or dual monitor guys...Can't see crane outrigger fully. Impression is he had been trying to counter lift of the steering end of crane. But my little knowledge of dozers says, according to the cylinder arrangements, their power is in the lift not resistance to pressure underneath. Boom angle I can't explain, why they aren't more perpendicular to front of sign and therefore vertical as can be with less extension?
    If this was completely manual jib or derrick, nobody would be so far off the plumb line. Physics are physics.
    I'll bet the crane operator stands on a street corner these days, spinning a pizza sign or wearing a hot-dog costume.
  10. #7
    Just to be clear it is a loader not a dozer from the size relation to the rubber tires I would say possibly in the Cat 966 of John Deere 640 size range
  11. The Following 2 Users Say Thank You to Frank S For This Useful Post:
    Jon (Dec 26, 2018), Toolmaker51 (Dec 27, 2018)
  12. #8
    PJs
    PJs is offline
    Sep 2014
    Northern CA
    PJs's Tools
    I can see the far side stabilizer @ :14 when the crane is more vertical. Not sure but it looks to me like the bucket is between the front wheels as I can see bucket in front (this side) of the outboard wheel. Either case someones got hell to pay for bad choices.
    Mark Twain
  13. #9
    Jul 2015
    Thank you. I was trying to decide if it was warranted to makje the same comment
    probably weighed a fraction of what a track layer would.
