Results 1 to 5 of 5
Thread: Mixing concrete using a rototiller - GIF
    NortonDommi (Mar 16, 2022), nova_robotics (Mar 16, 2022)
    hemmjo's Tools
    That is actually mortar, used to lay block and brick, rather than concrete. There is no course aggregate in it.
  4. The Following User Says Thank You to hemmjo For This Useful Post:
    Altair (Mar 13, 2022)
    meyer77's Avatar
    Feb 2019
    My brother said they used a roto tiller when he was working on a 175,000 sq ft marble job at a mall back in the day.
    Sep 2018
    nova_robotics's Tools
    That's a great idea. The consistency is probably not perfect, but for most pours it's probably fine.
    meyer77's Avatar
    Feb 2019
    The consistency is much drier than a concrete mix. It is called dry pack, pick up a hand full and squeeze it should compress to a firm ball, drop it to a hard surface it should break apart to a loose mix.
    Back in the late 90's my cousin and I did a boys school job, a little over 8,000 sq.ft. on "Mud",
    we used about 40 tons of sand and cement. His brother did a power plant floor in Idaho 64,000 Sq.ft.!
    On the school job I had a union helper working with us, Nicknamed Skippy he would pile sand and cement on the floor till about 6' high then mix it. He would say it almost mixes itself!
  8. The Following User Says Thank You to meyer77 For This Useful Post:
